Old 07-08-2018, 09:24   #11
fraatti
Tässä taas sanotaan että korealaisissa autoissa olis ollut paikallisen valmistajan egr. Ja muualla käytettäisiin jotain muuta. Mikähän on totuus ? Jossain uutisessa oli kuitenkin maininta että maailmanlaajuisesti käytetään samoja osia....
Deciding to recall a total of 106,317 units of the 520d sedans and 41 other models, BMW Korea admitted that the cause of fire was a faulty exhaust gas recirculation module, used for lowering emissions. The part was manufactured by a Korean parts maker.
Since December 2017, a total of 28 BMW vehicles have caught fire on motorways here. Of the total, 19 were the diesel version of the BMW 520, all manufactured before 2017.
"BMW Korea could have pointed out the EGR as the cause of the fire early, considering that it installed the faulty parts that were manufactured by a Korean parts maker, unlike vehicles sold in Europe," Ha said.
http://www.asiaone.com/asia/bmw-kore...faulty-engines
F11 535dX LCI
Old 07-08-2018, 15:39   #12
Vecara
Vecara's Avatar
Koreassa takaisinkutsutut autot. Mikä näissä tekee eron esim e90 330d N57 koneiseen? Vai eikö ko. Mallia ole myyty tuolla? Vai onko egr yksikössä jotain eroa?
Sinällään tuttu tarina: "When the component malfunctions, the emissions reenter the pipe without being cooled and melt a hole in the engine. The heat that comes out of the hole could cause a fire, according to BMW’s own probe so far. "
Mutta onko näihin tarvinnut liittyä jäähdytinnesteen vuoto?
"BMW blames a coolant leak in the exhaust recirculation module in diesel engines for the spontaneous fires, but the ministry has yet to identify the exact cause.."
Markkina on melkoinen... ja tehtiinkö nyt vain se mitä oli pakko kun luottamus alko oleen nolla. Eikai nämä mitään uusia ongelmia ole vaan jo tiedossa olleita?
"Korea takes up 30 percent of worldwide sales of the 5 Series.
BMW said, "All BMW models sold here are equipped with the same EGR systems and components designed by Germany as those of BMWs sold around the world. No fires of the BMW models caused by faulty EGR systems have been reported elsewhere."
Tiedän omasta tuttavapiiristä kaksi palanutta F11 520d:tä, toinen paloi ihan huolella ja lunastukseen, toinen ehdittiin sammuttaa ja riitti korjaus.
Molemmista lähti raportti liikkeen kautta BMW:lle, lunastetun auton kuuleman mukaan olisivat jopa halunneet Saksaan tutkittavaksi. Ja kummassakin ongelmana oli tuo EGR.
** MB CLS 350 SB -15** Alfa Romeo 159 3.2 JTS Q4 -06 ** Ski-Doo BC XRS 850 146 -18**
Vecara is offline   Reply With Quote
Old 07-08-2018, 16:48   #13
nullzwei
nullzwei's Avatar
Theoretisch könnten die Probleme auch in Deutschland und anderen Märkten auftreten, da die Modelle mit der gleichen Soft- und Hardware ausgestattet sind, bestätigte ein Sprecher von BMW Deutschland auf Nachfrage von »kfz-betrieb«.
https://www.kfz-betrieb.vogel.de/bmw...orea-a-739993/
E91 monacoblau 100%
Old 07-08-2018, 17:15   #14
Clavurion
Clavurion's Avatar
Aika eksoottinen tuo BMW:n insinöörien teoria glykolin, noen ja öljyjäänteiden muodostaman mähmän syttymisestä ongelman syynä.
E39 530dA -02 M-Sport
E53 X5 3.0dA -06 Sport
Old 07-08-2018, 17:28   #15
PNM2
Appiukon X3 20d:ssä vaihdettiin imusarja, koska se oli osittain palanut läpi. Vikakoodi esti isommat vahingot. Tämä ehkä noin 40000km ajetulla, eli meni kokonaan liikkeen piikkiin.
Old 07-08-2018, 22:02   #16
BFI18
BFI18's Avatar
Tuttua. Alkukesästä yhden tutun F11 520d syttyi palamaan hki-tku motarilla ilman mitään ennakkovaroitusta. Onneksi ei hlövahinkoja. Auto meni totaalisen poroksi.
F21 LCI M135i xDrive
Old 07-08-2018, 22:24   #17
suppari
Pari viikkoa sitten tuli korjaamolle kaveri koodien lukuun kun vikavalo taulussa, avasin pellin ja imusarjasta nousi jo sauhu Hienoja pelejä!
P:0409699000
huollot/korjaukset!
BMW E&F sarjaan.
Old 08-08-2018, 00:51   #18
fraatti
Just joo... Itsellä ei saksa taivu häävisti mutta jotain sellaistahan nuo taitavat virkata. Kumma kun muissa autoissa se ei syty....
Tässä vielä tuosta EGR:n toiminnasta muutama läpyskä. Onko vika nimenomaan ollut aina tuossa egr-venttiilissä vai tuossa egr-coolerissa olevassa ohivirtausläpässä? Onko tällä ohivirtausläpällä jotain tekemistä sen kanssa että tuo kenno palaa puhki? Tosin tuota ei taida olla kuin manuaalissa/suurempi koneisissa. Eikö vikakoodit laita autoa sellaiseen nilkutusmoodiin että imusatsi ei enää pala puhki? Luulis että ainakin venttiilin asennosta on tarkka tieto koska tuossa näyttää olevan asennon kertova potikkakin päässä.
Kuusmukisissa EURO 6:ssa sitten näyttää olevan egr:n lämpöanturi, tekeekö se siitä vähemmän paloherkän? Euro 5:ssa tuota ei ole.
Kuusmukisessa tuo ohitusputki on myös hiukan erilainen:
F11 535dX LCI
Old 08-08-2018, 01:09   #19
fraatti
Tästä se sitten ilmeisesti lähtee...
F11 535dX LCI
Old 08-08-2018, 09:54   #20
Robi
Robi's Avatar
Noita palaneita muutaman tehty duunissa. Viimeisin selvisi ns säikähdyksellä.
530xd kyseessä.
Kuvia tapahtumista
Robi is offline   Reply With Quote
E39 530d runaway diesel Raipe72 1996 - 2003 (E39) 19 21-08-2012 15:16
2009 BMW X5 Diesel Recalled Due To Fuel Heater Fault Taky Yleinen autoaiheinen keskustelu 0 01-09-2011 20:30
E39 takavalo palaa, ei pala, palaa himonussija 1996 - 2003 (E39) 2 23-08-2007 21:45
