Go Back   BTCF Forum > Kauppatori - Myydään > Myydään auto hi-fi
Old 11-02-2021, 12:44   #1
Daylight
Daylight's Avatar
Carpower CRB-12T Subwoofer
Käyttämätön paketissaan. Ilman koteloa.
Power handling (continuous/programme) = 2x100/2x200 W
Frequency range = 45-300 Hz
Resonance frequency fs = 31 Hz
Impedance R = 8 Ohm
Sound pressure level SPL = 87 dB (2,83V; 1m)
DC resistance Re = 2x3,9 Ohm
Force factor BL = 16,7 N/A
Voice coil inductance L = 2x1,1 mH
Effective piston radiating area Sd = 503 cm2
Effective mechanical mass incl. air load mms = 120 g
Equivalent volume of compliance Vas = 75 l
Total Q factor Qts = 0,61 (Qms=6,98, Qes=0,67)
Voice coil diameter = 38 mm
Maximum peak linear excursion vibration xlin = +/- 10 mm
Mounting diameter d = 280 mm
Overall diameter d = 310 mm
Mounting depth (not countersunk) t = 136 mm
H:50€
Helsinki
Privalla tavoittaa.
///M3
F30 330e M-Sport
Carly vikakoodinluvut + pienemmät koodaukset.
Daylight is offline   Reply With Quote
VAHVISTIN Monacor Carpower 2/400 900 W + SUBBARI Signum ESX SXB-250 10" (150€) villeval Myydään auto hi-fi 0 15-03-2015 20:57
E39 subwoofer liian hiljaisella sorsa Viihdelaitteet 10 16-02-2012 22:55
