Go Back   BTCF Forum > Mallisarjakohtainen keskustelu > 6-sarja > 2003 - 2010 (E63, E64)
Old 05-06-2016, 00:21   #1
B-Girl
iDive CCC ja päivitetty CIC
Olisi kiva kuulla kokemuksia iDrive CCC ja CIC versioista. Saattaa vaikuttaa lopulliseen valintaan.
CCC was one of the most controversial items on the BMW E63/E64 6 Series. iDrive is controlled using only a controller with two additional buttons below the controller. The buttons would send you back to the main menu and the other would activate the voice commands. All BMW E63/E64 6 Series' have a navigation system and iDrive CCC is disc-based, meaning you would have to buy a disc to run the navigation system. The use of a disc was no longer needed when iDrive CIC was introduced in 2009 (2010 for all US models), where it used a hard-drive based. Some 645Ci's had a different version of iDrive with a smaller 6.6" screen, and did not have some functions of iDrive CCC including a navigation system. This version was called iDrive Business.
iDrive CIC (the second generation version of iDrive) was then introduced on to European models in 2009, whilst some still had the old iDrive with the new controller. All BMW E63/E64 6 Series' had iDrive CIC by 2010. The controller featured more buttons for shortcuts, and featured 6 programmable buttons below the CD/DVD player. iDrive CIC featured a redesigned menu layout, graphics and hardware. The Voice Commands were also changed, as they were criticised for being too precise.
B-Girl is offline   Reply With Quote
Old 05-06-2016, 09:13   #2
Tommix
Tommix's Avatar
Täältä vaan lukemaan:
http://www.btcf.fi/forum/showthread....&highlight=Cic
ja
ja vielä päälle NBT
http://www.btcf.fi/forum/showthread....&highlight=Nbt
MYYTÄVÄNÄ N55 viriosaa
Old 05-06-2016, 13:57   #3
B-Girl
Löytyi: CIC tuli vasta 2009 vm.
Old 26-06-2016, 12:42   #4
B-Girl
Idrive CCC vai CIC?
Piti opiskella tämäkin. Miten tunnistaa idrive ccc ja idrive cic?
Käytettyä kutossarjalaista myyvä taho ei tiennyt (autokauppias!) kumpi idrive autossa on.
Vanhassa idrive ccc:ssa ohjain on yksinkertaisempi ja näytössä navikointi "neljään ilmansuuntaan osoittava".
Päivitetyssä idrive cic:ssa ohjaimessa enemmän nappuloita ja näyttössä navikointi "viuhkamainen".
Korjatkaa, jos satuilen.
Onko uudessa idrive cic:ssa softapäivityksiä, joita voi tehdä tai teettää bmwlla?
Jätin juuri tarjouksen 2009 630i E64 mallista, jossa näyttäisi olevan tuo uudempi idrive cic.
Kuvat alla:
Vanha idrive ccc ohjain ja näyttö.
Uudempi idrive cic ohjain ja näyttö.
Old 26-06-2016, 12:44   #5
B-Girl
Uudempi idrive cic, jossa ohjain kehittyneenpi ja näyttö viuhkamainen.
Old 26-06-2016, 16:42   #6
Tommix
Tommix's Avatar
CCC 2 kpl CD/DVD pesää kojetaulussa. Ohjaimessa 2 kpl painonappia.
CIC 1 KPL CD/DVD pesä kojetaulussa. Ohjaomessa monta painonappia ylä- ja alapuolella.
Ainakin E60:tä löytyy kyllä sitten CCC:llä ja uudella ohjaimella...
On, mutta marmori päivittää sitten koko auton, kestää. Mutta paikallinen harrastaja voi päivittää pelkän CIC:nkin.
Old 26-06-2016, 20:08   #7
B-Girl
Sorry...en asu Suomessa ja kieli hieman vaikeaa. Mikä on marmori?
Mitä muuta autossa päivitetään?
Old 26-06-2016, 20:38   #8
Tommix
Tommix's Avatar
Marmori = merkkiliike. Eli sinun tapauksessa juuri sielä voit tarvittaessa päivittää CIC:n ohjelmat.
E60 CCC vs. CIC JKK Viihdelaitteet 141 13-12-2017 18:00
CIC dvd toisto ongelma Allianz Viihdelaitteet 5 08-02-2016 22:42
E60 CCC, CIC Combox, Ym. Tofu 2004 - 2009 (E60, E61) 74 17-07-2015 13:33
O: E61 lci ccc / mask2 / cic MajorDrake Ostetaan BMW osat ja tarvikkeet 1 18-03-2015 15:01
E61 CIC etupaneelin valot ei toimi, sähkö tulee oikeaan pinniin PetriPT 2004 - 2009 (E60, E61) 8 28-08-2014 17:16
