Old 12-05-2021, 15:02   #1
Shadow651
Takaniskatukien irroitus E93 cabriolet
Apuva...
Lähteekö voimalla vai kikka kolmosella E93 cabrioletista (vm -12) takaniskatuet irti? Pitäisi asennella niiden väliin tuulensuojapleksi, mutta ei ole mitään irroituspainiketta ja ei ne ainakaan hellästi ylös nouse?
Shadow651 is offline   Reply With Quote
Old 12-05-2021, 16:23   #2
peltone
peltone's Avatar
https://www.bimmerfest.com/threads/e...ovable.196789/
To answer my own question: Delivery specialist and I determined that the rear headrests can in fact be removed. Process is easy - pull them straight up and they come out cleanly.
Process is difficult: these suckers are really stuck in place (but intended to be removed as described - no harm done).
Process leaves the ugly not-intended-for-viewing front face of the pop-up rollover bars showing plainly, so trade-off is between seeing these in the rear-view mirror or seeing the headrests there instead.
With headrests removed, you gain about 2 inches more visibility out the rear, which may not sound like much but which gives much better view of cars in your starboard-quarter blind spot, so no easy answer. Would love to see someone come up with covers for the popups.
E30 316 2D sedan -87
E91 325i touring -06
E61 530d touring -06
ex. E30x9, E34x2, E39x2, E36x2 E46x2
Old 12-05-2021, 18:16   #3
Silmaauki
Silmaauki's Avatar
Originally Posted by Shadow651 View Post
Apuva...
Kunhan saat ne irti ja pleksin kiinni, niin laita kuvia pleksistä.
Mistä pleksi on hommattu?
E93 335i Aarre, Montego blue
E90 318i talvipulkka
Silmaauki is online now   Reply With Quote
Old 13-05-2021, 12:07   #4
Shadow651
Ebay ja pitäisi olla jotain "aurinkolasi" materiaalia (kovamuovi tai lasi)... kuvan mukainen ja laitan vielä kuvan miten se omaani istuu kunhan postista sen saan
Name:	Screenshot_20210513-120032_Samsung Internet.jpg
Old 13-05-2021, 12:36   #5
Silmaauki
Silmaauki's Avatar
Jos vaan muistat, niin ota kuva vielä kun pleksi on jo paikallaan, mutta niskatuet ei.
Mua kiinnostaa se miten lasin sais tuohon kiinni siististi ilman turhia näkyviä asennusreikiä.
Old 13-05-2021, 13:41   #6
Shadow651
Alkuperäiset ruuvit joilla "turvakaari" verhoiltu korvaantuu pidemmillä ja menee siis samoin reikiin. Niskatuki siihen eteen ja ei kyllä pitäisi mitään jäädä näkyviin
Old 13-05-2021, 19:13   #7
Silmaauki
Silmaauki's Avatar
Tuo vaikuttaa fiksummalta kiinnitykseltä kuin se mitä joskus aiemmin katselin. Siinä kiinnikkeet ruuvattiin ”hattuhyllyyn”. Siinä tosin oli lasista eikä akryylistä kyse. Akryyli on pehmeämpää ja naarmuuntuu helpommin, joten sitä en haluaisi käyttää. Mutta tuolla samalla kiinnitystavalla voisi ehkä tuohon saada lasinkin kiinni. Vähän riippuu siitä paljonko siinä välissä on tilaa.
Old 06-06-2021, 18:43   #8
Silmaauki
Silmaauki's Avatar
Onko jo tullut ja onko asennus onnistunut?
Kuva? 😎
325i cabriolet E93 (vm 2012) pitkät valot Shadow651 2006 - 2011 (E9x) 3 04-02-2021 14:18
BMW 335i E93 Cabriolet 2008 BmwUser1991 2006 - 2011 (E9x) 7 06-12-2020 23:49
Takaniskatukien irroitus e46 touring,KIIRE wmb330d 1999 - 2005 (E46) 4 29-10-2010 16:02
